uTonic MIDI Output
Steven Sauve129 views3 posts
  • Steven Sauve
    I know that uTonic can output the sequencer patterns in realtime MIDI. It'd be great to be able to use uTonic as a MIDI FX device, specifically in Logic. This would make uTonic's excellent sequencer available to easily control other drum sources. What's involved in making the software designation for a MIDI FX device?
  • JBDS1
    1. Create a channel in Logic , add Microtonic, make a beat.
    2. Create a second channel add your Drum source ( Logic drum kit, NI Battery, etc ), go to Environment and drag a cable from top right channel 1 (where you loaded the Microtonic) to the top left corner of the channel 2 ( Logic drum kit, NI Battery, etc ).
    3. Done
    You can use the Microtonic sequencer in this way .. i guess :)
  • JBDS1
    it not working.. i guess it works only with VST and not with Au instruments.. use Ableton :)))
