(uTonic)Trouble with Program Changes in Ableton clips
Christopher Holland1 659 views4 posts
  • Christopher Holland
    With most vsts in ableton you can use clips for program changes as seen here.
    uTonic does not seem to respond to these program change commands. Does this simply not work or am I doing something wrong?
    Yes, support for MIDI Program Changes is something we introduced in MicroTonic v3.0 and it should definitely work. To begin with, could you verify that program changes are enabled in your default MIDI Config. Check page 27 in the User Guide: http://cdn.soniccharge.com/public/MicroTonic%20User%20Guide.pdf?m=20110525141333 . If it is not turned on, turn it on and click "Make Default".
    Let us know if this solves your problem or not.
  • dave dove
    hey Magnus
    i'm having this problem too
    there are three dialog boxes:
    Bank
    Sub
    Pgm
    i have tried setting the program number only
    and then variations of the others
    to no avail
    i have enabled program changes and set it as default
    dave
  • dave dove
    of course
    if i put the control clip in a separate track
    then it works fine...
    doh
    dave
