Microtonic Problems with Loop MIDI Host
joe cavalry86 views2 posts
  • joe cavalry
    I am using a midi host called Loop MIDI (V1.0.16 (27).
    The last row of Microtonic (Stop, Play, Step Rate, Swing, Fill Rate, Master) is not working properly.
    When I click Play, the Step Rate jumps to the right.
    When I click stop, the Step Rate jumps to the left.
    When I click and drag the Step Rate slider, the Swing slider moves also.
    When I click and drag the Swing slider, the Fill Rate slider moves also.
    When I click and drag the Fill Rate slider, the Master moves also.
    Actually, clicking and dragging a Drum Patch slider or knob, causes another slider or knob to also move.
    I would like to know what's causing this and if possible, fix it. Maybe a configuration issue?
    Thank you for your time.
    -j
  • AAV
    Loopmidi, as far as I know, ( https://www.tobias-erichsen.de/software/loopmidi.html) is a virtual midi cable that uses virtual ports to route midi from one source to another. It's not a host and isn't capable of generating midi commands by itself. So you'd have to provide a lot more information about your setup. (How you're actually hosting and how you're trying to trigger Microtonic.)
