If MicroTonic fails AU scan in OSX 10.7.5...
Scott Oram898 views2 posts
  • Scott Oram
    Hello,
    I wanted to report something in case someone else runs into it.
    I noticed that some of my plugins were not showing up in logic anymore so I did a little investigating and found out that 10.7.5 has an issue with signed developer properties, causing things to fail.
    This is what you will see in the AU validation window: ERROR: -2147450878 IN CALL Remove Property Listener
    Things started validating again once I installed the "SUPPLEMENTAL" update here: http://support.apple.com/kb/DL1599?viewlocale=en_US&locale=en_US
    Hope this helps,
    Scott
    aka elipsis1
    - elipsis1 wrote:
    Hello,
    Hope this helps,
    Scott
    aka elipsis1
    Thanks a lot for this info. We have received some support emails concerning this and I didn't know that there was an update to fix it already.
