Synplant 2 "Error Initializing AI Engine"
BananaLizard312 views8 posts
  • BananaLizard
    When I try and use the Genopatch fucktion, it gives me 2 errors. first saying this:
    Then says this after pressing "OK":
    I must've reinstalled 3 times with no luck, does anyone know how to fix this?
  • BananaLizard
    FL Studio 21 Windows btw
    What is the full path of the "Installation Folder" you use? It's the 3rd page of the installer
  • Davide Palandri
    same problem here, and the path is the same of the image up here
    Please send a screenshot of the exact install location and a video of when the error shows up to support@soniccharge.com
  • Niko Rauscher
    is this solved ? i got the same problem even after reinstalling multiple times
  • Manuel Senfft
    Not sure, if this could make a difference, but you could consider updating your FL Studio version. Latets one to this date is v25.2.5.5319
    We have identified a possible issue when Synplant 2 is installed or run from a path containing characters outside ISO-8859-1.
    The default installation path should normally not contain such characters, so we would like to confirm which path is being used on your system.
    Please send us a screenshot of the exact Synplant 2 installation location shown in the installer, maybe with a short video showing when the error appears, to support@soniccharge.com. That should help us verify whether this is the issue or something else.
