Waveform modulation
Martin Jaroš149 views3 posts
  • Martin Jaroš
    Hi all,
    may I ask, is there any way how to modulate waveform in Synplant 2? I mean we have b_form that changes waveform shape and timbre, and I would like to set parameter that under some frequency, let's say middle a, it would be higher and then waveform will be sharper, and above this frequency, it would be automatically lower, then waveform will be less sharper. Maybe some way in mixing two oscillators? I tried to do this but I was not successful... Thank you and enjoy summer!
  • Martin Jaroš
    I would be very glad for any short advise, thank you...
  • Hektagon
    The only way is to use external modulation... try automating the parameter in your daw. or you could try using the bulb mode ranges and have slightly different variations on each, just edit the genome for the ones on a specific key range?
