Synplant2 Makes Ableton 12 crash
Martin Moreels227 views1 post
  • Martin Moreels
    Hi !
    I would like to try Synplant 2 but everytime I launch it on Ableton 12, the DAW crashes instantly (and the vst doesn't open).
    I'm running Windows 10 Version 22h2 build 19045, 4651
    Ableton 12.0.15 (Build 2024-07-15_98b4d22779)
    Here is the log generated when I open Synplant 2 :
    "024-07-24T14:56:00.401329: info: VST3: Going to create: Synplant
    2024-07-24T14:56:00.404103: info: VST3: plugin processor successfully loaded: Sonic Charge 'Synplant' v2.0.1.285 (cid: {5653544E-7553-5073-796E-706C616E7400})
    2024-07-24T14:56:00.420746: warning: VST3: setProcessing returned error: not implemented
    2024-07-24T14:56:00.423052: info: VST3: parameter count is 140
    2024-07-24T14:56:00.423597: info: VST3: Created: Synplant
    2024-07-24T14:56:00.436059: info: VST3: couldn't get controller state of Synplant: not implemented
    2024-07-24T14:56:00.599997: error: Windows Exception: EXCEPTION_ACCESS_VIOLATION
    2024-07-24T14:56:00.600020: info: Exception: Fatal Error: Unhandled exception
    Thanks for your help !! :D
