Map custom Midi CC to change presets in Synplant
Tim Wolf212 views8 posts
  • Tim Wolf
    Hey guys, first time poster here. I'm looking to achieve the following:
    I want to be able to browse presets (aka go back and forth in the currently loaded preset folder) without having to reach for my mouse or trackpad. I was able to achieve this in Serum by mapping the corresponding CC value to two buttons on my Launchkey Mini Mk3. Is this possible in Synplant as well, or is there perhaps a better solution?
    I have the newest version of Synplant installed and I am on MacOS if that is relevant at all. Thanks!
  • Laszlo Umbreit
    Hello Tim !
    I’m looking for the exact same thing to play synthplant in a liveset, did you get any promising leads?
    Thank you,
    Laszlo
  • Manuel Senfft
    You can open the file dialog, which will bring up the OS file open browser. With that you can select a file in the dialogue still open and already play the preset. With that you can e.g. skip to the next preset with the arrow down key and play the preset on your midi keyboard.
  • Laszlo Umbreit
    Thanks for the tip! So I guess there's no cc for "next/previous" preset.
  • stelvia
    You can MIDI map a Program Change device's previous/next buttons.
    It works great!
    Just keep in mind that Synplant has a weird 16 Program Change limitation.
    I've been requesting a regular 127 slots for years, that will probably never happen :/
  • stelvia
    If you need more than 16 presets to scroll through, you can have several Synplant instances.
    Each instance can have its own MIDI Program List, and this way you could overcome the 16 slots limitations
  • Laszlo Umbreit
    Waow Thanks so much for the tip, that's great!
    Where do I find the Program Change (in Ableton for instance?).
    I'll start looking for it, thank you!
  • stelvia
    late reply sorry,
    so you can either program the program change in the MIDI clips themselves (in Ableton it's located in the clip's Launch tab)
    Or (my preferred way) you can download a Max for Live Program Change device, there are plenty free :) Just try to get one with previous and next buttons
