Ableton 9.5 cant find bitspeek
Skye77 views7 posts
  • Skye
    I had an older version of bitspeek for a while but never used it, i had a project perfect for it so i decided to buy it, but i had trouble authenticating it, a forum goer suggested that its because it was an old version of bitspeek so i downloaded and installed the newer version. I can see the new bitspeek Dll file in my VST folder but i cant see it in Ableton 9.5 32 bit (the older version did work in trial mode) can anybody see what im doing wrong.. i never usually have this problem.... honest :)
  • AAV
    You are using a 32 bit host, but the newer versions of the Sonic Charge plugins are 64 bit only - I think unless you can run a 64 bit version of Ableton, you might try the 32 bit version installer in the "Old Archived Versions" section on the download page.
    Requirements
    The minimum requirements for installing and running Bitspeek are:
    • Microsoft Windows 7
    A host that supports 64-bit VST 2.4, or VST3 plug-ins
    • macOS High Sierra (10.13)
    A host that supports 64-bit VST 2.4, VST3, or AudioUnit 2 plug-ins
  • AAV
    https://soniccharge.com/public/Sonic%20Charge%20Plugins%202022.03.21.zip
  • Skye
    Thanks, Ill try that and get back, btw thats why i clicked vst2 only on the installer.
  • Skye
    ok that worked and it also authorised thank you, time for some fun 8)
    just out of interest i have version 1.6.2 is that the newest 32bit version ?
  • AAV
    Looks like it is, yes
  • Skye
    Ahh ok thanks.... ;)
