Scale modulation - Synplant 2
Martin Jaroš62 views1 post
  • Martin Jaroš
    Hi all,
    I have a theremin instrument and I try to reproduce this kind of a scale for a long time. Please see an attached file. It is sound based on modulation of two oscillators, tubes behavior etc., which is very hard to emulate in any VST or some sample. Is anybody able to reproduce it in Synplant? Or do you have recommendation for other software? I successfully reproduced always only part of this scale, low or high register, but there is still missing that continuos modulation - if I reproduce sharp low tones, high tones are also too sharp, or when I reproduce the higher tones, lower tones are also too soft or even muffled. I would like to achieve that exact modulation and achieve this sound from the recording, this is something like an "ideal" sound for theremin players, very hard to emulate. Is somebody able to do this? I would be very grateful.
    Thank you very much!
    Martin
    Clara theremin scale.mp3
