Microtonic + FL midi drag n drop woes
Jacob Cheney90 views1 post
  • Jacob Cheney
    Heyo - recently purchased microtonic. Whenever I drag a pattern that's been set to either of the triplet rates (1/8t or 16/t) - the midi doesn't loop correctly at all. The only remedy to this is to export to audio first and then line up the midi (it comes with a bunch of silence) and cut it from there. So far so good. But... is there a setting somewhere to avoid this?
    I found this forum post w/ a similar issue a while ago. Is this just a problem w/ FL being weird about some midi file metadata? I couldn't find much info online about this.
    Thanks! :)
