Alter panning amount per branch in Synplant?
Manuel Senfft62 views3 posts
  • Manuel Senfft
    Hey there, is there any way to modify the panning amount for each branch individually, when the branches get extended?
    The only way to lower the (often times unwanted) stereo effect with each not getting their own stereo panning seems to be the main effects slider. But maybe I want the effects and not the panning randomness. Any ideas?
    Yes, use the adj_pan gene in the gene editor.
    When it is less than 0.5 it will lower the panning amount for extended branches. At 0.0 there is no panning whatsoever. Above 0.5, the panning effect will also be introduced for branches that are not extended.
  • Manuel Senfft
    Oh, I must have missed this parameter; even after explicitly looking for such a parameter before I posted this question here. Thanks for your reply, Magnus! I will check it out later. (=
