by pass does not work on cubase
ALAIN DUFRASNE71 views2 posts
  • ALAIN DUFRASNE
    Hello, I have a problem with your plugin permute, it does not bypass cubase 14 do you have a solution for this?
  • ALAIN DUFRASNE
    i've explained myself wrongly it doesn't register the bypass with the w function during playback sonic charge support tells me everything's fine it's been tested it's my pc that's the problem or my lack of experience
    i have 20 years of experience with cubase and i've tested it on several pc's. it's the same problem and the vst 2 is not recognized scanned and then disappeared, neither in the list of active plugins, nor in the black list.
    and you can assign the bypass to additional buttons from cubase 14 and there's a (!) which means that the function can't be automated, which makes this plug-in useless, especially as it doesn't need a source to make sound, which is a disappointment as it's not real modulation but a signal mix plus a sound that modulates on many presets.
