Synplant genopatch save all iterations
Riki Keckarovski152 views4 posts
  • Riki Keckarovski
    Can you please make it possible to save all or let's say selected iterations of Genopatch into separate presets, that would be a pleasure as it spits very good variety of slightly different iterations of a fed sample.
    Thanks and Peace ✌
  • Andy Music
    Search for Synplant 2 scripts and find the Batch export script
  • Riki Keckarovski
    Hey Andy,
    Thanks for this fast reply. I found this post somewhere in the forum and I downloaded this scripts
    But now when I run Synplant this dialog appears:
    It took me a while to figure out how this script works so I fed Genopatch with sample and run the process in Genopatch.
    "And now what" I asked myself trying to find out some right click command that will provide me with "Save all branches" or whatever Menu, that I couldn't find anywhere, so I closed Synplant window in my DAW.
    So when I reopened it, this popup message came out:
    Now that was cool I selected a folder and it saved all generated results from Genopatch.
    But my question is this ... Can this Script be a little refined in terms of providing right click menu in Genopatch, in which you will select the folder to save the results. This way it is useful but a little bit annoying. Also I did't try this in standalone mode.
    Anyway thanks a bunch and Peace.
  • Riki Keckarovski
    As I suspected, it doesn't work in standalone mode.
    I will try to refine this script it is my task now ;)
