Micro Tonic 3 - Rendering Timing Issue
Darren Payton766 views2 posts
  • Darren Payton
    Hi, firstly gotta say what a wonderful plugin microtonic 3 is, i'm blown away by the drum combos you can create
    Setup: Windows XP Service Pack 3, FL studio 9, Microtonic 3
    i have noticed that when you bounce a drum loop made by micro tonic and reslice the loops after the first hit are ahead of where it should be this increases the more microtonic plugins u have open, i have a tested with a project with 15 microtonics open and it is almost 1/4 step ahead after the first hit(i think the first hit gets chopped a little from the beginning of the sample) when u render anything out of the project with or without other vsts included.
    have tried various projects and problem is still there, also i have tried increasing the asio latency and tweaking buffer size but this didnt work either, also i tested this in fl studio 10 and problem is still there but only a slight amount
    please contact me if you need any more info or project examples
    many thanks
    Darren
  • Darren Payton
    Hi, I was wondering if you guys are any closer to resolving this topic
    many thanks
    Darren
