Audio from Bass Drum only (Row 1) in Step Sequencer
ANDREW STEVENS54 views2 posts
  • ANDREW STEVENS
    Hello - WHen I have the Step Sequencer going and playing a pattern with steps on all 8 rows, I only hear row 1 (Bass Drum). I imagine this is a configuration setting that I am not seeing, but I can't find it and didn't find an existing support topic. How do I get sound from all rows? I am using Mac Sequoia 15.6 and did the 30 day trial before purchasing the full version.
    Did you by chance load the multi-out version of Microtonic? If so, each channel has its own separate audio output, and it must be routed inside your host.
