Microtonic 32 bit
gentleclockdivider gentleclockdivider176 views6 posts
    The 32 bit version is not available in the installer package
    I really need it to run it inside Audiomulch
  • AAV
    Last 32 bit version : https://soniccharge.com/public/Sonic%20Charge%20Microtonic%203.0.1.zip
    I really dislike the sonic charge installer , it automatically deinstalls the 64 bit versons of micro-tonic
    Why does it do that ?
    All I want is an additional installation of the 32 bit plugin so it can run inside audiomulch
    Iirc , there has to be a more recent tonic
    The gui wa way flatter than this one
  • AAV
    Probably right actually. I found that link as "last 32 bit ONLY" version. There are two newer versions, that likely also include 32 bit versions. Check this one (3.2), but if not there is a 3.1.x version as well. These are located on the downloads page, under "additional downloads", then under "old archived versions".
    https://soniccharge.com/public/Sonic%20Charge%20Microtonic%203.2.zip
  • toitoy
    Audiomulch😍
