Synplant 2 _ Genopatch_All generated Patches into Folder Save
Enimem114 views1 post
  • Enimem
    Hello to the Soniccharge Humans.
    To the users of this wonderful tools and the people who make them work!
    I have more then once come to this conclusion and wanted to bring it up on here...
    cause maybe im not the only one that would think of this as a very nice and practical feature...
    That would maybe even be easy and quick to implement.
    There have been a lot of moments, where i put a sample into genopatch, let it do its satisfying thing... and then realise that i want to save and cherish 80% of the generated material atleast...
    And that for 4-5 samples i am experimenting with... well that is truly a LOT of saving and naming to do... holy cow.
    So it would be wonderful, if thered be a drop down menu option (where ""plant seed"", ""new random seed"" etc also has its place) where one could just click -> Save all genopatch "snakes/branches/whatevers" into a folder, where maybe branch 1 - 4 is a base way of naming all the "samples" (i mean presets of course) sitting in that branch and then a small popup gives you the possibility to give all the samples a generalized name probably per branch too and then assignes them a number, starting from the bottom of the branch.
    That would be a crazy time saver, and also big experimentation helper.
    EXTENDED TO THAT:
    -> It would be sick if there would be a Synplant Mode / or also just a dropdown menu item, that would place all of the branches sounds into the current patch... if that would make any sense or would be doable... now that i think of it... hmmm xD
    -> What would also be crazy for usability reasons in a daw, sample export for all of the branches sounds, with one click, in a once set export folder... And that way sampling crazieness and further tinkering would work in a super efficient way!
    Im curious what you all think about this!
