recording sound design sessions and VST host advice(paid software)
Itay avigdor765 views3 posts
  • Itay avigdor
    Hello Everyone,
    I am new to sound design and looking for any advice concerning a simple VST host software (windows based and not a freeware, so I will be able to have customer's support for it) that can handle Synplant plug-in and also allows to _record a session_(is it called MIDI recording?), so I can record not only the result (as wave file) but also the changes that are done while I play with synplant.
    It could be wonderful, as I can record the changes as they are made, interactively, and to re-play them afterwards.
    I do no know what to look for- for a MIDI recorder? for a VST host software? Maybe something that have both? etc.
    I will be thankful for a simple and easy to use, and not so expensive, software ideas to the above.
    Many Thanks!
    Hey,
    As I do not actually use Windows for music making myself, I do not have any preferred host to advice you. For Synplant, you will want to find any good host that supports 32-bit VST plugins. There are a lot to choose from and all of the ones I know have trial so you can try them out.
    I will list a couple that I know is popular among our users.
    Ableton Live 9 - https://www.ableton.com/en/trial/
    (Make sure you use 32-bit version of Live as its 64-bit version does not support Synplant)
    Reaper - http://www.reaper.fm/download.php
    Studio One - http://studioone.presonus.com/free/
    Sonar X2 - http://www.cakewalk.com/Products/SONAR/Web-Trial.aspx
    FL Studio - http://www.image-line.com/downloads/flstudiodownload.html
    Maybe someone else on the forum that reads this can chime in what host might be good to start with for Itay?
  • Itay avigdor
    Thank you!
    It is good enough for me to check.
    Many thanks for your reply as well as for your amazing work and software!
    Itay
