Microtonic doesnt show up
D'Mo Mo56 views3 posts
  • D'Mo Mo
    Hi Sonic Charge,
    I have a registered copy of Microtonic. It appears in Logic Pro’s Plug-in Manager and shows as validated/available there, but it does not appear in the instrument selection menu when I try to load it on a software instrument track.
    This started happening in the later versions of Logic Pro 12.0.1 on my MacBook Pro M4. I have already restarted the computer and rescanned the plug-in, but the issue remains.
    On my older Logic version (10.7.8), it works normally. The problem seems specific to the newer Logic version(s).
    Do you know if this is a compatibility issue with Logic 12 / Apple Silicon / AU validation, or if there is a known fix?
    I’ve attached screenshots showing that Microtonic appears in Plug-in Manager but does not show up in the instrument list.
    Thanks.
  • AAV
    I'm on Windows, but I am running Version 3.3.4 of Microtonic as a VST3. Are you sure you are running the latest version? (Your screenshot shows 3.3.0)
    Hi. Our plug-ins are fully compatible with the latest Logic 12 and Apple Silicon. From your screenshots, it looks like Logic is mighty confused. Please try this:
    1. Quit Logic
    2. Clear Logic’s plugin cache
      • Open Finder
      • Press Cmd + Shift + G
      • Paste this: ~/Library/Caches/AudioUnitCache/
      • Delete everything in that folder
    3. Restart your Mac
    4. Open Logic again
    Let it rescan plugins (this may take a moment) and let us know if it helped.
