seed volume management
Marco Pietro Boglione33 views3 posts
  • Marco Pietro Boglione
    Hi to everyone. I'm trying out Synplant 2 but I've already decided to register. I have a question. I'll use the Echoes preset as an example. I play a C note on my midi keyboard, then with the mouse I want to apply the effect to the note, so I click on the seed of the branch corresponding to the C note. The sound and the effect produced are spectacular, but too loud and ruin the ambient atmosphere of the song. I haven't been able to find a way to play the seed at a lower volume. Is it possible? Thanks for your attention and kind regards.
    Not sure I understand your question correctly.
    Why not reduce the "Volume" slider at the lower right of the bulb in Synplant? Or level on the channel mixer in your host?
    Or is it the fact that the MIDI note velocity is different from the mouse click velocity? Did you try adjusting the velocity slider at the bottom right and the velocity setting in MIDI Settings?
    You can also map branch length to host automation to avoid using mouse clicks inside the bulb (since it triggers new notes).
    i try to explain better... i hope. Sysplan 2 is loaded as vst in FL Studio
    i load Echoes [Solar Fire] track 1. The volume of the track is setted as default in the mixer
    i play C3 with my Oxygen 49 midi keybord with velocity 47 and the note sounds with the volume i have setted.
    I keep the note held and i click on the C seed with mouse without dragging it. I heard a sound like "sdlenggg" which has a much higher volume and does not fit well in the context of the song.
    I tried to lower the volume using the slider on the right but it lowers the entire volume including that of the note and it doesn't solve the problem
    the same thing happens with others preset. its seems to me the volume of the seed is highter than the note. Many Thanks for your attention. i will register for sure next days
