Synplant will not update to Version 2.0.2
Paul Kemp35 views2 posts
  • Paul Kemp
    Phenotype says it requires an updated version to run. I have version 2.0.1 and I
    m using the update program after uninstalling Synplant, but it will not update to 2.0.2 . Is there some other way I need to uninstall to update? Or is there a link I could get to the actual most updated version file?
  • Paul Kemp
    I figured out the problem, basically. I had made a backup of the VST in the folder that REAPER scans, so it kept using the old version in the backup. I had to move the backups to folders that REAPER does not scan and then install Synplant 2.0.2 then it worked.
