µ-Tonic Not Showing Up On Nuendo 6.03 64 bit Windows 7
Christopher Hoffee919 views2 posts
  • Christopher Hoffee
    Hello,
    I just installed the latest 64bit update to µ-Tonic on my Windows 7 64 bit Nuendo 6.03. I can see it in my Plugin list on Nuendo, but it will not show as an option to use. I uninstalled the previous version as instructed, authorized through the website. But alas...it cannot be seen or used.
    Thoughts?
    Thank you for your time.
    Hi there,
    I do not personally have any Nuendo to try it out on, but my best guess is that Nuendo is still listing the old plugin that was removed from the system. Did you try to do a full scan of VSTs? I supposed Nuendo has such an option somewhere in the preferences?
    Also good to note on the issue:
    • The default of the Windows installer is to install 64-bit plug-in only in your C:\Program Files\... folder. The previous version installed a 32-bit plug-in in the C:\Program Files (x86)\... folder.
    • The actual plug-in dll file has changed name from MicroTonicVST.dll to Microtonic.dll, some hosts do not handle this change as perfect as they should.
