Synplant not showing up
Kendrick Hughes542 views2 posts
  • Kendrick Hughes
    Hi there Synplant is not showing up in FL Studio 11.02 32-Bit nor is it showing up in Cubase 7.05 32-Bit, Nor Renoise 2.8.1. however oddly enough it shows up in Maschine 32-Bit. Any ideas?
    Sounds odd. Now I only tested Synplant in FL Studio 11.02 64-bit, and that worked without problems on my Windows machine after I added the Program Files (x86) folder as an additional VST folder in the preferences. Are you sure that all your hosts are looking in the correct VST folders? Do you have other VSTs in the same location that turns up?
