Not able to locate BitSpeak after install
Brandon Thibodeau701 views3 posts
  • Brandon Thibodeau
    I recently purchased BitSpeak and I am having difficulty getting it to install properly. I have tried installing and un-installing multiple times with no luck. After install, the VST does not show up anywhere in my VST Folders within Ableton.
    I am using Ableton 8 with wondows 7 64 bit on PC. I have left all of the defualt information as is during install and all of my VSTs are installed in the Program Files/Native Instruments Folder.
    There should not be any problems loading Bitspeek in Ableton 8. Please note that on a 64-bit Windows systems Bitspeek is installed in two locations. By default, the 64-bit is under the C:\Program Files\ folder while the 32-bit version is under the C:\Program Files (x86) folder. Just make sure the correct path has been added to your extra VST plugin paths inside your host.
  • Brandon Thibodeau
    Thanks for your response. I didn't find it in both places but I did end up finding it in the 64bit folders so I just copied and pasted it where I needed it and all is good now :)
