Bitspeak in Logic X?
Adam Watson675 views2 posts
  • Adam Watson
    I just purchased Bitspeak, but it is not showing up in Logic X. Looking at the AU file, it seems to be only 32-bit... does this plugin not support 64 bit? I hope I didn't just waste my money, since the product description gives no warning that this is 32-bit only.
    Hi,
    If you have installed the latest version of Bitspeek it is both 32 and 64-bit and should show up in your Logic X. To make sure that it is installed correctly you can run the following command in a terminal window:
    auvaltool -q -v aumf NuSq NuEd
    It should show up as:
    --------------------------------------------------VALIDATING AUDIO UNIT: 'aumf' - 'NuSq' - 'NuEd'Manufacturer String: Sonic ChargeAudioUnit Name: BitspeekComponent Version: 1.0.2 (0x10002)Component's Bundle Version: 1.0.2--------------------------------------------------WARNING: Recommended Property is not supportedWARNING: Recommended Property is not supportedAU VALIDATION SUCCEEDED.
