Microtonic only has sound on C3 in Ableton Live?
Tricky_Toxic_STL463 views3 posts
  • Tricky_Toxic_STL
    I just bought Microtonic and when I load it in Ableton Live 9, I can only get sound on the first channel (C3). I cannot get sound to come from the other 7 channels. I've tweaked parameters on all channels but cannot get sound from them. Is there something I am doing wrong or is Microtonic not compatible with Live 9?
    There are two different plugins, one simply called "Microtonic" and another called "Microtonic Multi". It almost sounds to me like you are using the "multi" version?
    Otherwise I am not sure what is wrong. Microtonic is fully compatible with Live 9.
  • Tricky_Toxic_STL
    Thanks for the reply. I was using the Multi version but a little later I realized that may be the problem, then tried the regualr version and it works fine. Problem solved. :)
    Now I am watching a youtube tutorial about how to set up the multi version with Drum Rack so I can use Microtonic on my Push. Once I get this done, I'll be set. :)
