Export Pattern To Audio File
Nowhk868 views4 posts
  • Nowhk
    I see I can export Pattern Chain to Audio File.
    But how can I export a single Pattern (such as A or B?)
    And what if I would like to export Single Pattern Channel for Single Pattern? (such as Pattern Channel 3 or Pattern B).
    Is it possible? Next feature?
  • Elevated_Being
    Couldn't you just record the pattern and delete the B pattern in the recording?
  • konfront tama
    how is this accomplished? id love to be able to export to audio file.
    You can of course also turn off the pattern chain, select the individual parts and export them. Same with exporting a single pattern channel. Alt-click a mute button to solo a channel and choose export.
    @Konfront Tama: "Export Pattern to Audio File" is available under the pattern menu if you have purchased Microtonic.
