Synplant no sound logic x
Pim van Horssen1 136 views9 posts
  • Pim van Horssen
    I'm using the latest version of synplant on my macbook pro retina running the latest version of logic.
    For some reason I can't get any sound out of synplant anymore.
    It runs as usual, i can browse presets and everything looks in order
    But when im playing either the midi keyboard, writing in the piano roll, or just simply clicking in the syntplant window I can't get any sound out of it.
    It used to work just fine, but for some reason it stopped working...
    I have tried reinstalling without any luck
    Sorry for the late reply. Do you still suffer from this problem? If so, have you had the possibility to try a different host (e.g. the free VSTLord http://arne.knup.de/?page_id=32) just to eliminate the possibility that it is a Logic setting causing the problem.
    Does it look like Synplant tries to generate audio when you play MIDI? E.g. do the branches sway etc? Or is there simply no response at all?
  • Elliot Davies
    I seem to be having the same problem, I can click on the key buttons inside of Synplant and it will play but external midi in my arrangement or from a controller doesn't register at all. I've tried other synths and they work fine.
    Ideas?
    Ideas?
    But you are saying the GUI buttons do work. In this case I would suggest first checking "MIDI Config..." to see that the MIDI receive channel is set to "any".
  • Elliot Davies
    Yeah, it's odd. It's not a Logic setting though, any other synth works perfectly fine in its place.
    But Synplant does not receive midi from any external means. I've tried uninstalling and reinstalling with no Joy.
    Any ideas? :)
    Elliot
    Did you already check that Synplant is indeed receiving MIDI on any channel? As in this picture:
  • Elliot Davies
    That fixed it, thanks! Rather strange that it would default to that.
    Glad it worked. But yes I agree, very strange. Which channel was it set to?
  • Elliot Davies
    16 interestingly.
