Synplant FL studio 10 -.-.-.-.-
nadjet288 views2 posts
  • nadjet
    Hi, I didn't ork to read through all the forum, it may be so someone experienced the same problem as I.
    I'm having problem getting the synplant vst to work?
    I tried install it directly to the fl vst map but it didnt work either..
    any suggestions on what i should do?
    xoxo
    Latest version of Synplant works fine in my FL Studio. Make sure you check the path in settings and install the correct version (32/64 bit) in the correct path for FL Studio.
