Retina support
Mads Martinsen203 views8 posts
  • Mads Martinsen
    Will there be support for my iMac retina display in the future?
    Hopefully. We have looked into the technology but haven't started researching how well it is supported by the major DAWs. Apart from compatibility another concern is actually download size. We don't want to go the "all vector" route with our plug-ins as seem to be the trend right now, but rather continue to combine vectors with Fredrik's exquisite 3D renders. Today we use only non-lossy compression for graphics, but with Retina this means 4 times as much data.
    All taken into consideration I'd say Retina will probably cost us a few months of development time in total so it is not something that we can just toss in there.
    Fredrik's GUIs in higher resolution do look mighty tasty though. Check it out:
  • Mads Martinsen
    That looks amazing here. I'd gladly give an arm and a leg (and the added filesizes) to be able to stare at that loveliness while working!
  • Valery Kondakoff
    Magnus, can you, please, explain: what are the benefits of this high resolution render if it looks rather blurry on Retina display?
    Here is an example. The small fonts are almost unreadable on my new Retina iMac:
    We do not support Retina yet as I explained in this thread. The larger image I posted was mainly to demonstrate that we have renders in higher resolution that we'll hopefully see in our plug-ins in the future. But quite a few technical hurdles to tackle before that.
  • Valery Kondakoff
    Thank you for explanation!
  • colin
    sorry to revive the old thread, but I just upgraded to a retina MBP and wanted to know it there is any ETA on the retina interfaces? :)
    Sorry, no ETA on it. What I can say is that I have put some work into it and that I would like all our products to have retina support. I will continue working on it and hopefully we can get it into an upcoming update.
