Echobode only vst plugin on Mac OS X?
Michelle Christiansen371 views3 posts
  • Michelle Christiansen
    Hallo, I just installed the trial version of Echobode. Now as I am a Logic Pro X user, I would like to use Echobode in Logic Pro X. But after installing, Logic Pro X did not recognize any Echobode AU plugin. I looked it up in the plugin folders and recognized that it was installed as a vst plugin, but not as AU plugin. Is the AU plugin just missing in the installer, or did I do something wrong?
    Do you mean that after installation you cannot find an Echobode.component in your /Library/Audio/Plug-ins/Components? As we use Symbiosis it is actually the exact same binary as the .vst, but must be copied to the Components directory and renamed to .component. The installer should do this as one of the last steps. Could you please retry installation and check?
    Ok, I can confirm it works now. There seemed to be a permissions problem. But now everything is fine. Thank you for helping me!
