Echobode suddenly flashing "disabled"
Kit Ebersbach237 views4 posts
  • Kit Ebersbach
    My new Echobode, after working well for a few days, now is flashing "disabled." I tried re-registering it, but I was prompted that it was already registered. How can I get my echo bode to work again?
    My DAW is DP8.07 on an IntelMac 10.8.5.
    "Disabled" flashes when the processing in Echobode is being "bypassed" by the host. I am not familiar with DP8, but could you please check that you haven't by mistake hit some bypass or off-switch?
  • Stephen Falk
    Im having the same problem with DP9...hmmmm..
    and I can assure you disabled is not active, nor is there any automation that should
    be switching it on
    When this happens, does Echobode not process the sound going through it?
