Synplant (no sound)
buy anonimus1 586 views6 posts
  • buy anonimus
    Synplant (no sound)
    hello Im trying synplant trial and I didn't get any sound! im testing on cubase and fl studio...
    is something there that can cause this problem?
    Are you trying to play it from MIDI or does it not even make sound when you click inside the interface?
  • buy anonimus
    any sound.... playing from midi or interface...
  • buy anonimus
    not sure if this must be done from beginning but I opened "MIDI Config" and then I clicked Reset and is working now....
  • buy anonimus
    is this correct configuration?? or is something wrong?
    No that looks correct. It should be correct by default. Only situation I know of where it is not, is in a bad cracked version I have seen circulated. It messes up default settings and it is not reset by reinstalling, you need to do it manually as you did now.
    Just make sure you download the installers from our site and never anywhere else.
