Microtonic Morph automation not recording
sxip shirey163 views3 posts
  • sxip shirey
    in Ableton OSX.
    Is this a common problem?
    How do I solve this? I can draw it in of course, it just wont record the changes in the silder as I play it.
    Thanks.
    Sxip
    Odd. Are you using AU or VST? I just tried it in Live 9 with both the VST and AU versions and it recorded both fine. However the AU also recorded all parameters that were morphed which isn't what you want normally. (I think I know why, and it is unavoidable if the AU should pass "AUVal". Just use the VST version in Live :) )
  • Gene Sxip Shirey
    I am using AU, I will try using the VST version and see what happens, thanks!
