Patternarium mixing chain ?
Svet124 views2 posts
  • Svet
    I'm curious to know if you use specific mixing chain on Patternarium's page. It sounds really deep, loud and clean. I'm wondering if some specific EQ/Comp/Limiter are applied there. Thanks !
    I am pleased to hear that you like how it sounds cause there is no processing done at all. The audio is straight from Microtonic.
    I use a volume normalization algorithm that allows a little digital clipping to get consistent loudness across different patterns without losing too much gain. In other words some patterns might clip a little in order for others to play loudly without clipping. That's the only thing that affects the sound quality, except for the variable bit-rate MP3 streaming format.
