microtonic not found
amit dhar94 views2 posts
  • amit dhar
    Hello I upraded to Live 9.6.1 and now i receive a message that Microtonic plugin could not be found. please help
    Windows? Then make sure you are using the correct version of plugin 32/64-bit in the correct path.
    Mac? Most likely you need to double check that the plug-in preferences inside Live is correct so that VSTs / AUs are not disabled.
