Randomizing trigger&velocity with intensity function
Michael Schirmer345 views3 posts
  • Michael Schirmer
    Tattoo from Audio Damage is not one of the best step sequencers but it has one very nice function: you can create your own trigger and you can create a probability for additional triggers with a fixed or variable velocity.
    This function is not huge but a nice little addition for creating ghost notes for your percussion lines or even more in depth sound designing.
  • Marcus Lind
    When the X/Y pad appeared in Logic's Drummer with which patterns would automatically change from simple to complex, from soft to loud I was immediately convinced that this will be in other DAWs/plugins. Now it's in Steinberg's Groove Agent 4 and also Softube's heartbeat. It's a great feature! What are the chances to have it in MicroTonic? Maybe with an option for randomized vs fixed variance per play? Because in certain cases you want the results to sound the same.
  • Michael Schirmer
    "Maybe with an option for randomized vs fixed variance per play?"
    This would be great!
    I would record the midi and would use it in my DAW also for other tracks.
