Adobe Audition
Brandon Truscott268 views2 posts
  • Brandon Truscott
    I am using Adobe Audition CC 2015.1 on a Macbook Pro OSX Yosemite 10.10.5. I downloaded your complete Sonic Charge Plug-in Bundle trial package and installed the following: Echobode, Permut8, Bitspeek, Synplant and Microtonic.
    I can see that all of the VST's were successfully installed into the correct folder /Library/Audio/Plug-Ins/VST. I used the Audio Plug-In Manager inside Audition (https://helpx.adobe.com/audition/using/adding-third-party-plug-ins.html) to Scan for Plugins and it will find: Bitspeek, Echobode, and Permut8 which I can use. But, no matter what I do, uninstall, re-install, manually copy the files, etc. Audition will not recognize Synplant and Microtonic.
    Please advise... (The products are fantastic and I intend to purchase them if I can get them to work correctly.)
    Hi Brandon. Unfortunately I do not have an up-to-date version of Audition to test with (I need to get that sorted). It sounds to me like our effects are popping up but not our instruments. When I googled on this I found this forum post: https://forums.adobe.com/thread/309622
    In the post it sounds a bit like Adobe has two different plug-in managers for effects (VST) and instruments (VSTi)? I am not sure, but could that be it?
