Microtonic Midi mapping parameters?
James242428 views2 posts
  • James242
    Hi, when in edit midi cc mode, what are the 3 parameters for each drum channel button? The first plays the drum, the third is for the mute button. What does the second middle parameter do (mapped to c2 in the below image)?
    I'm trying to find a parameter that will allow me to map controller buttons or notes to switch which drum is visible WITHOUT playing a drum sound. Is this possible?
    Thanks!
  • timbralzoom
    c2 is the Note name that triggers the Mute ... you can define the midi CC number via click drag in bottom (...) if you want to control mute button with midi cc
