Separate instruments in FL Studio 12
Kosta Kosta1 129 views7 posts
  • Kosta Kosta
    Yo, how to to create a separate midi track for each drum channel in FL 12?
    Not sure I understand what you are trying to do. Each drum in Microtonic responds to a different MIDI key. You can always route multiple MIDI tracks to the same Microtonic, but you will still have to use different notes for the different channels; unless you use a separate instance of Microtonic for each drum.
  • Kosta Kosta
    I want to do the same thing like this guy had done in this video
    YouTube Video
    On the 1 minute
    I want to do this thing
    Kinda like to eq or compress each instrument in microtonic
    Is it possible?
  • The Hypnotist
    Open Microtonic in channel rack. Click the gear icon at the top of the vst. Click the icon with the plug and gear. Beneath that, click "processing". Here you will see the 8 outputs at the bottom where you can individually assign them to whichever mixer tracks you want.
  • Robert Michael Goodwin
    Collier Adaire Thank you so much for this post! I spent about 3 hours looking around on both the Sonic Charge forums and FL Studio forums before I found this explanation. Bingo. In seconds, I had parsed the 8 tracks of the Microtonic patch into separate channels in the FL Studio Mixer.
