Pitch rising delay in Obliter8 demo...
richard carrigan323 views2 posts
  • richard carrigan
    How would I go about making the sound at around 1.32 here:
    obliter8dissection by malstrom
    It's kind of similar to the continuos rising of echobode, but with a nice lofi graininess to it.
    Bought Permut8 yesterday, have no idea how to use it for specific effects yet, I've just scanned presets trying to understand what is happening, and quite franky it's bonkers!
    Is there a firmware recommended for pitch-twisting delay lines? Or can anyone suggest the steps one would take to re-create a similar sort of sound?
    Cheers in advance :)
    I can't remember if that exact program is in any of the factory banks but I called up the Obliter8 project and copied it. Here it is:
    Permut8ProgramV1: {
    	Name: "reverse delay 1"
    	Modified: true
    	InputLevel: -17.54459953 dB
    	Limiter: Off
    	FilterFreq: HP 1278.87646484 Hz
    	FilterPlacement: Input
    	FeedbackAmount: 88.00000000 %
    	FeedbackFlip: On
    	FeedbackInvert: Off
    	OutputLevel: 22.04934692 dB
    	Mix: 33.50000381 %
    	ClockFreq: 1/4
    	SyncMode: Standard
    	Reverse: Off
    	Operator1: MUL
    	Operand1.High: 0x81
    	Operand1.Low: 0x07
    	Operator2: SUB
    	Operand2.High: 0xE0
    	Operand2.Low: 0xFF
    (You can copy the text from above and paste it directly into Permut8.)
    The trick is using the MUL instruction to speed up the playback. Each feedback will be pitched up slightly from the previous.
