Microtonic - How to avoid clicks in sound, when muting/bypassing mc-instances via midi controller button?
Erich Maibaum134 views2 posts
  • Erich Maibaum
    Hi from Wuppertal/Germany
    Is it possible to avoid clicks in sound (and re-record tracks), if i bypass/mute one or more instances of Microtonic via a midi controller?
    If not, is another solution possible to achieve this state?
    Thank you for response ...
    Erich
  • Erich Maibaum
    The solution was probably too close: mute the mixer channels leads to the desired result :-)
