Microtonic
Darren Murphy268 views3 posts
  • Darren Murphy
    Hi, i haven't used the Microtonic drum machine for a little while but when i went to use it recently all that seems to be available for me to use, and this seems to be going on with every kit available, only the kick drum can be heard or programmed. Seems odd, even when i scroll up and down the key board, only the kicks triggers. Can anyone shed any light onto this problem? The odd thing is, is that the project i first used it on triggers all the sound from a kit but now i am only with kick drums from all kits?! Odd...
    regards
    Darren
    Triggering from MIDI or do you mean channel 2 to 8 does not make any sound at all? If you only get sound from channel 1, make sure you are not running the multi-out version without routing audio out from all channels.
  • Darren Murphy
    cheers Fredrik, ill will check, thanks.
