synplant skin
philter759 views9 posts
  • philter
    seems like this SYNPLANT skin i made in the past does not longer work
    with newer versions of synplant. where do i have to put the synplant resource folder now to make this work again? anything else i have to do to make the synplant.dll using the edited GUI files in my synplant resource folder? any information how to solve this problem is appreciated.
    thx
    The file pointing to the resource folder should now be called "Synplant V1.2 Resources.txt". We have added the version number to this file name because mods for one version are not guaranteed to be compatible with other versions.
  • philter
    okay thx magnus.
    same for microtonic ? and where do i have to put the ressource folder and the text file?
    in the same folder where the microtonic.dll is installed?
    Either you create a folder next to the Microtonic DLL called Microtonic V3.2 Resources and fill it with your custom resources, or you place a text-file called Microtonic V3.2 Resources Path.txt next to the DLL that contains the full path to a different resource folder.
  • philter
    thank you!
  • philter
    hmm tried both ways but it does not work
    Not sure why. This is what it looks like on my PC for instance:
  • J. Pablo Arceo
    Can this be done on a Mac?
    Yes. Same thing but put the file or folder in /Library/Audio/Plug-Ins/VST/Sonic Charge.
