TX16W Hardware & Software
Klang Verbieger899 views8 posts
  • Klang Verbieger
    Hi,
    I`ve got an TX16W hardware sampler, and I think that Cyclone is cool. But - I love the machines.. Does anyone know which type of disk drive is built in the machine - and how to replace it with a standard disk drive?
    I know it`s not cool to talk here about hardware - but, isn't it the same when I'm using TYPHOON OS? :)
    When you say "replace", do you mean replace a faulty drive with one with identical specifications, or are you after something else?
  • Klang Verbieger
    Hi Magnus,
    I've got a lot of floppys here :) Well, I think it isn't easy to get a identical drive - so, is it possible to use something else? I've seen some SD-Card things.... but that would cost a lot of money. Is there a cheap way to get my two TX16Ws alive?
  • Andreas Marco
    - Klang Verbieger wrote:
    Hi,
    I installed a Gotek USB HxC in my Yamaha TX16W and works great .. :)
  • Manu Sese Puertolas
    Andreas, could you explain how to copy the waves of the 2.5" floppy's in the USB memory? And the edited parameters of the loops, envelopes, etc?
    I suppose that with the 4.5 GB of maximum internal memory, there will be no physical way to expand, thanks.
    regards
